AWMN
Settings value of column based on selected column in a summary table
Hi experts.
I have a linked summary table, in which i select rows, based on a criteria.
In my main table, I now need to set a specific value in a column, for the selected rows.
I have made a basic table with the following:
Sample   error
s1            0
s1            0
s1            0
s2            0
s2            0
s2            0
I have some very simplified code as an example:
dt = current data table();
dt_sum = dt << Summary(
Group( :sample),
Freq( "None" ),
Weight( "None" )
dt_sum << select where (:sample == "s1");
r = dt << get selected rows;
close(dt_sum, nosave);
column(dt, "error")[r] = 1;
The code runs, if the dt_sum is closed. In my code however, this is not possible, as it is needed later.
I get the following error, if dt_sum is not closed
"Cannot set value for the column 'error' because the row number (-1) is not valid.{1}"
Further more, the error value for line 1 and 4 is changed to 1, but not the rest.
Can any of you explain me why this is not working, or help me with a possible workaround?
Thanks in advance, Anders
Re: Settings value of column based on selected column in a summary table
1.  I think you should submit the issue to JMP Support.  It appears that eventhough you are directly pointing to the "dt" data table, it is still looking to the "dt_sum" data table and updating there.
2. Here is a work around that allows the code to work
Group( :sample),
Freq( "None" ),
Weight( "None" )
//close(dt_sum, nosave);
current data table(dt);
Group( :sample),
Freq( "None" ),
Weight( "None" )
AWMN
Thanks, that does it :)
