jpol
How to script the 'Make into Data Table' function under Graph Builder for wafermap image creation
I am using the Map shape and Page functions of Graph Builder to create wafermaps of Test Measurement data.
See example below:
 After this I use the "Make into Data Table" function which gives me a  new table having a wafermap image for each  wafer ID.
These images are used  later as a mouseover Labels  in Time Series plots.
I would like to script the task of making wafermaps into a data table  but unfirtunately there is no "Source" script in the Graph Builder Table apart  from Copy Table Script.
Is there a command within JSL that would enable me do this?
Thanks,
Philip
JesperJohansen
Re: How to script the 'Make into Data Table' function under Graph Builder for wafermap image creat
I'm sorry, I think I didn't understand your issue entirely the first time. Try this:
1)
Make Graph, e.g.:
gb=Graph Builder(
Size( 534, 1454 ),
Graph Spacing( 3 ),
Variables( X( :X ), Y( :Y ), Page( :Z) ),
Elements( Points( X, Y, Legend( 9 ) ), Smoother( X, Y, Legend( 10 ) ) )
Note that i store the graph builder as "gb" to reference it easier later.
then use:
gb<< Make Into Data Table;
Hope this helps?
BR
Jesper
JesperJohansen
Try:
dt = Report( gb[1] )["Summary of Fit"][Table Box( 1 )] << Make Combined Data Table;
where the data table is aved as "dt", and the graph builder is saved as "gb". The script makes a report, looks for the 1st Table Box in "Summary of Fit"  (you would look for a different part) within saud report.
Hope it helps
BR
Jesper
jpol
Hi Jesper,
Thank you for your reply.
Unfortunately I have been unable to script this action as I had hoped as I do not understand fully how your example script works.
I am still a newbie in the scripting arena.
In my case, using a data query script I have collected all the chip level data into a Data Table "Probe data".
I then construct the wafermaps using a Graph Builder script,
after which I manually run the "Make into Data Table" command from the Graph Builder pull down menu in order to get the wafermap images into a new data table , Graph Builder Table
Could you please explain how your proposed script  fits into these steps?
Thanks,
Philip
JesperJohansen
1)
Make Graph, e.g.:
gb=Graph Builder(
Size( 534, 1454 ),
Graph Spacing( 3 ),
then use:
Hope this helps?
BR
Jesper
jpol
Thanks Jesper,
This is exactly what I needed.
Best Regards,
Philip
Level XIII
Hi, I really like the Make Into Data Table - it's sooo useful!
This time I have a Graph with columns used as GroupX, GroupY and Page.
How can I tell Jmp that I want a data table for each page - but nut for each subplot per GroupX/GroupY?
