swiergi11
How to save control charts and its summary to the same slide in ppt
I've got script which creates block of Control charts with capabilities based on the parameter and i would like to save each report for each parameter into separate ppt slide. Any help appreciated.
Here are the charts:
and i would like to have each parameter chart and report on separate ppt slide:
Attached is the table with Control chart script.
Thanks,
Tomasz
PS. and if it is possible  to save only the charts which have Ppk below 1.33 then it would be magnificent
Re: How to save control charts and its summary to the same slide in ppt
Add the below JSL to the bottom of your script and you should get what you want
nw = New Window( "Control Charts",
	V List Box(
		obAge = Outline Box( "Control Chart for Age" ),
		obWeight = Outline Box( "Control Chart for Weight" ),
		obOxy = Outline Box( "Control Chart for Oxy" )
ob = Outline Box( "", hlb = H List Box() );
hlb << append( Report( gb )["Levey Jennings of Age"] );
ob2 = Outline Box( "Distributions" );
ob2 << append( Report( gb )["Age"] );
hlb << append( ob2 );
obAge << append( ob << get picture );
hlb << append( Report( gb )["Levey Jennings of Weight"] );
ob2 << append( Report( gb )["Weight"] );
obWeight << append( ob << get picture );
hlb << append( Report( gb )["Levey Jennings of Oxy"] );
ob2 << append( Report( gb )["Oxy"] );
obOxy << append( ob << get picture );
nw << Save Presentation( "$TEMP/jmp_example2.pptx" );
Open( "$TEMP/jmp_example2.pptx" );
nw << close window;
This question has been asked before.  Here is a link to the way I approach the issue
How to save journal as PPT (2 graphs per slide) using JSL
Here is a complete example, using your data that creates the output you want
	ob1 = Outline Box( "Levey Jennings of Age" ),
	ob2 = Outline Box( "Levey Jennings of Weight" ),
	ob3 = Outline Box( "Levey Jennings of Oxy" )
cc1 = Control Chart(
	invisible,
	Sample Label( :Name ),
	KSigma( 3 ),
	Chart Col(
		:Age,
		Levey Jennings(
			Show Zones( 1 ),
			Shade Zones( 1 ),
			Test 1( 1 ),
			Test 2( 1 ),
			Test 5( 1 ),
			Test 6( 1 ),
			Test Beyond Limits( 1 )
		Capability(
			Distribution(
				Continuous Distribution(
					Column( :Age ),
					Quantiles( 0 ),
					Horizontal Layout( 1 ),
					Vertical( 0 ),
					Outlier Box Plot( 0 ),
					Normal Quantile Plot( 1 ),
					Process Capability(
						Use Column Property Specs,
						Process Capability Analysis(
							Nonconformance( 0 ),
							Histogram( 1, Show Within Sigma Density( 0 ) )
					Customize Summary Statistics( Skewness( 1 ) )
cc2 = Control Chart(
	invisible,
	KSigma( 3 ),
	Chart Col(
		:Weight,
		Levey Jennings(
			Show Zones( 1 ),
			Shade Zones( 1 ),
			Test 1( 1 ),
			Test 2( 1 ),
			Test 5( 1 ),
			Test 6( 1 ),
		Capability(
			Distribution(
					Column( :Weight ),
					Quantiles( 0 ),
					Vertical( 0 ),
					Process Capability(
cc3 = Control Chart(
	invisible,
	KSigma( 3 ),
	Chart Col(
		:Oxy,
		Levey Jennings(
			Show Zones( 1 ),
			Shade Zones( 1 ),
			Test 1( 1 ),
			Test 2( 1 ),
			Test 5( 1 ),
			Test 6( 1 ),
		Capability(
			Distribution(
					Column( :Oxy ),
					Quantiles( 0 ),
					Vertical( 0 ),
					Process Capability(
ob1 << append( cc1 << get picture );
ob2 << append( cc2 << get picture );
ob3 << append( cc3 << get picture );
nw << Save Presentation( "$TEMP/jmp_example.pptx" );
Open( "$TEMP/jmp_example.pptx" );
swiergi11
Hi Jim,
This looks very well and dose excellent job but is there a way to do similar job but keep the integrity of the original control chart script unchanged?
I'm extracting the capabilities from all charts so i need them in one block.
I do lake the approached you mentioned in the How to save journal as PPT (2 graphs per slide) using JSL , is there a way to modify that script to work with control chart script?
Thanks,
Tomasz
	V List Box(
nw << close window;
swiergi11
Hi Jim,
That is exactly what i needed, thanks a lot.
Tomasz
