vharibal
How to save a jmp data table after its downloaded from sql query
I am importing data from data base and would like to save the data table. The data table takes some time to get downloaded. I would like to detect when the datable is downloaded and then save it at a location. Below is the code i tried.
The first part of extracting data table is happening fine.
The second part (highlighted in blue ) of detecting the data table once its downloaded and open is not working. I a, using
"get data table list" and printing that value once data table is downloaded.
// Extracting data table from data base //
ex1 = New Window( "TRIAL_1", << modal,
panel Box( "NAME",
H List Box(
Text Box( "batchid:" ),
teb0 = Number Edit Box()
panel box("SELECT",
h list box(
ok_button = button box("OK",
a = teb0 << get;
obj = New SQL Query(
Connection( "ODBC:DSN=SLT Data Server" ),
QueryName( "t_wlan_mfg_data" ),
CustomSQL(
Eval Insert("SELECT *
FROM t_wlan_mfg_data  t1  where( t1.batchid = ^a^ );")
) << Run;
// Waiting for data table to save //
i=1;
while (
i,
(l = get data table list();
show(l);
if (
Nitems(l)>0;
show(l);
break();
"no";
i++,
Re: How to save a jmp data table after its downloaded from sql query
If you don't mind JMP to wait for the query to finish you can use << Run Foreground instead of <<run (you should in my opinion always use either << Run Background or << Run Foreground instead of <<Run) and then save the data table when JMP continues the script execution. Other option is to use << On Run Complete (scripting index has simple example), and save the table with that( SQL Messages (jmp.com) ).
