JmpLearner1
Bar Graph with brackets
Hello everyone, I need some help with bar chart in JMP. I guess there is a two part for this question:
1. I have the following dataset in a long format :
Value: Column number
2                1
3                1
4                1
5               1
7              1
8              1
9              2
10           2
11           2
12            2
I used the Graph Builder to do the following graph: Bar Graph 1.jpg
I would like to add brackets between graph with the significance stars that indicates whether there is a significant difference between the means of the two groups. Could you help me do that?
2. My second question would be, is there a way I can produce this graph from having a wide format?
For example: if my data looked like this:
Colum1: Column 2
2              8
3              9
4                10
5                11
7               12
Thank you, I appreciate all the help.
Re: Bar Graph with brackets
Part 1:
I will provide the same solution I did last time "This blog post might be able to get you started Using JMP to create SuperPlots".
Using annotate tools
Part 2:
Using tall format data is much easier for this type of plot. You can do something like this by adding extra column for x-axis and then using multiple plots and disabling variables
JmpLearner1
Thank you for your help, can you give more information on how you reached your graph in the long format?
I was only able to reach the following:
Thank you!
  1. Add new column with just single value. I used numeric nominal column with all values of 1 (you could also use transform column for this if you don't want to have it in your table)
  2. Add two SEPARATE x-axis both using this new column
  3. Add both columns to Y-axis
  4. Add bar charts and points to your plot
  5. From the left side disable Variables from other y-axis so on one plot you show only Column 1 and on the other Column 2
Two separate X-axis
Column 2 disabled from the "left plot"
