Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMPĀ® Marketplace
HSS
HSS
How to run a part of script or include a script based on a condition
Hi All,
I am trying to run a part of a script based on condition on a column. If that condition is failed, it should run other part of the script or include other script.
It seems very simple but I am not able to do that. I have followed two approaches - using  "include" function to call a script  and "Expr" function to call a part of the code. None is working. Any help here ?
1st Approach -
dt = Data Table( "Data" ) << If ( PRODUCT == "A", include("C:\....\Script1.jsl"), include("C:\....\Script2.jsl"), );
This is not working while both scripts 1 and 2 are working independently.
2nd Approach is similar to 1st but using "Expr", the way mentioned in - Sectioning or Segmenting Code in JSL
Many thanks,
3 ACCEPTED SOLUTIONS
Re: How to run a part of script or include a script based on a condition
I believe the issue you are having is in attempting to pass the If() statement to the data table.  What should work is
dt = Data Table( "Data" );
I think we might need a bit more information about what you are trying to do and what the "external" parts are. Include() and expressions should both work just fine if you are just running parts of some code.
exprA = Expr(Show("A"));
exprB = Expr(Show("B"));
PRODUCT = "B";
If(PRODUCT == "A",
	exprA;
	exprB;
I ran this code without error
b = 1;
If( b == 1,
	Include( "path to one of the includes" ),
	Include( "path to the second include" )
The first include code was
a=1;
show(a);
The second include code was:
a=2;
show(a);
and it worked as expected
As @jthi has suggested you probably need to provide more information about the includes.
HSS
HSS
Hi Nelson,
I have tried that as well. That is also not working.
PRODUCT = "B";
If(PRODUCT == "A",
	exprA;
	exprB;
b = 1;
If( b == 1,
a=1;
show(a);
a=2;
show(a);
HSS
HSS
Hello @txnelson  and @jthi,
Actually both of yours codes are working fine (and in fact, my own way is also working). The issue was with JMP session.  After few more attempts my JMP crashed and I gave up. Today after restarting the JMP, the same code is working fine. I believe it may be same memory/cache/path/variables issue with JMP session. Once it is restarted, it worked fine.
I am really thankful for both of yours support.
Reards, HSS
Happens from time to time. If you aren't already, I suggest starting all your scripts with
It will provide you some protection against namespace collisions. This link is fairly helpful regarding Names Default To Here(1) (there is multiple pages)  Scripting Guide > Programming Methods > Advanced Scoping and Namespaces (jmp.com)
HSS
HSS
Thanks Jarmo,
I learnt using
from Nelson (@txnelson) few years back and I do use it. I will have a look into the guideline again.
Thank you guys.
