UserID16644
How to replace specific words in multiple column names?
Hi all,
Is it possible to replace the column names which contains a specific word? For example, my column names are Name, Age, New_Address, New_School, New_Number. And I need to replace the word New with Current or columns that may contain the word New ---- my new column names will become Name, Age, Current_Address, Current_School, Current_Number. TIA
Re: How to replace specific words in multiple column names?
Here is one way to do it
colNames = dt << get column names( string );
For Each( {col}, colNames,
	If( Contains( col, "New" ),
		Column( dt, col ) << set name( Substitute( col, "New", "Current" ) )
You can also use Recode Column Names for this.
