ASullivan
How to replace selected values in a column with JSL
Hi everyone,
I'm looking to replace alternate values in a column in using scripting. I've managed to select the values in the table but I'm struggling to find a way to replace them in just 1 column only.
This is my code so far:
Names Default To Here (1);
dt << new column ("selection", formula (sequence (1,2,1 ))); dt:selection << delete formula; dt << select where(:1 & :selection !=1);
This is the table it creates:
I want to replace the values highlighted in the first column with 0. Any advice on how to accomplish this would be appreciated. Thanks!
Re: How to replace selected values in a column with JSL
:Name("1")[ dt << get selected rows ] = 0;
ASullivan
Thank you @txnelson
Also wondering if its possible to then combine the 2 columns into a new column and excluding the 0 values?
define "combine the 2 columns"
Add them together?
ASullivan
By combine I mean have all the data in 1 column and disregard the 0 values, to end up with a table like this:
dt << new column("Final Data", formula(:Area remaining water +
:area remaining exo));
ASullivan
Thank you so much! Really helpful!
You need to do some reading. The Discovering JMP and the Using JMP documents. They are found in the JMP Documentation Library under the Help pull down menu.
