HarriBradbeer
Change date format in a script
I have a script that requires the user to input a batch creation time. It currently looks like this:
New Window( "BATCH_CREATE_TIME",
	<<modal(),
	Panel Box( "Enter BATCH_CREATE_TIME",
		Lineup Box( N Col( 1 ) ),
		number = Text Edit Box( "01/01/2021 09:00:00.000000" )
	Panel Box( "Actions",
		H List Box(
			Button Box( "OK",
				keep_going = 1;
				BATCH_TIME = number << Get text;
			Button Box( "Cancel", keep_going = 0 )
I want to update this so that it automatically puts the current time into the text box, so far I have this:
CurrTime = As Date(Today());
	<<modal(),
		number = Text Edit Box( CurrTime )
		H List Box(
			Button Box( "OK",
				keep_going = 1;
Now all I want to do is change the output to match the original format. I currently get the format "01Jan2021:09:00:00". Ideally, I'd like this to be "01/01/2021 09:00:00.000000" (the decimal seconds aren't vital).
Any ways that I can change the format of the As Date function?
Thanks all.
Re: Change date format in a script
Your input field is a text box, so you need to convert the date from a numeric number of seconds, to a string using a format() function
CurrTime = format(As Date(Today()),"m/d/y h:m:s",6) ;
	<<modal(),
		H List Box(
			Button Box( "OK",
				keep_going = 1;
	<<modal(),
		H List Box(
			Button Box( "OK",
				keep_going = 1;
