Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
ambs
How to replace Missing Values w/ '0' using JSL
How do I replace Missing Values w/ '0' using JSL?
I can do this manually using 'Find and Replace All', but I need to incorporate it in a code that runs automatically everyday.
13 REPLIES 13
RaginCajun
Re: How to replace Missing Values w/ '0' using JSL
This works when I am running it from a scripting window using play button, but not within a debugger or launching it by autorun of the .jsl.
dtLongestWaitStates << set name( "LongestWaitStates" );
dtLongestWaitStates = Current Data Table();
nc = dtLongestWaitStates << get column names( numeric );
For( i = 1, i <= N Items( nc ), i++,
	nc[i][dtLongestWaitStates << get rows where( Is Missing( nc[i][] ) )] = 0
RaginCajun
JMP13.2.1
jkwiggins
Another way...
clsMat = dt << Get As Matrix( {"colA", "colB"} );
clsMat[Loc( Is Missing( clsMat ) )] = 0;
:colA << Set Values( clsRej[0, 1] );
:colB << Set Values( clsRej[0, 2] );
etc.
logical indexing is often faster than loops
Jason Wiggins
masakit
cool! ... in the last 2 lines, clsRej should be replaced to clsMat, right?
meanwhile, do we have any similar solutions for character column?
msharp
Since no one else answered, the solution is the same, just grab character columns instead and set the rows equal to the character you find fitting--"N/A" in the below case.
Just be careful, setting it =0 will change the column to numeric and will remove all the character data, however ="0" should be fine.
nc = dt << get column names( Character );
  nc[i][dt << get rows where( Is Missing( nc[i][] ) )] = "N/A"
