kaushik_pushpen
How to remove title from Variability chart ?
Hello all,
I want to remove the title coming in my variability chart  "Variability Chart for CD-Value" automatically for the purpose of printing.
How can i proceed to it?
Please guide me. Thanks in advance.
robot
Re: How to remove title from Variability chart ?
If you want only the graph, without any reference to the title texts, one way is to create a journal of only the parts you would like.  You can then print the journal.
// Example.
bigClass = Open( "$SAMPLE_DATA/Big Class.jmp" );
var = bigClass << Variability Chart( Y( :height ), X( :age ) );
rvar = var << Report; // Create display box reference.
graph = rvar[List Box( 2 )]; // Create graph reference.
graph << Select;
graph << Journal;
graph << Deselect;
KarenC
Or you can use the selection tool (the fat plus sign on the tool bar) and select the portion that you want to print, cut and paste it into another application (such as a slide or a word processing program) and print from there.  You should also take a look at Daniel Vs recent blog post on graphics: Preview of 2015 Discovery Summit Presentation on Best Practices for Producing High Quality Graphics ....
Karen
kaushik_pushpen
Thanks Karen
kaushik_pushpen
Thanks Karen for the reply.
In my variability chart one is Title and second is "Variability chart for height" coming. I just want to remove second one list item not the title.
Your program is working OK. But it is removing title also.
Please suggest me.
Thanks in advance.
mpb
mpb
The code I posted on August 6 works for me on JMP 12.It displays the Title ("Variability Gauge") and removes the text "Variability Chart for height". What happens when you run it?
Michael
mpb
mpb
This example may be helpful:
Variability Chart(
    Y( :height ),
    X( :Age ),
    Variance Components( Nested ),
    Show Points( 1 ),
    Std Dev Chart( 1 ),
        Dispatch( {}, "Variability Chart for  height", OutlineBox, {Set Title( "" )} )
Phil_Kay
Lots of great answers here.
Useful tip: to remove any title from within a report, double click on the text of the title, delete all the text, and hit enter/return. The title will vanish!
