How to remove shading area around graph builder
When outputting the graph itself using Graph Builder, if you select the selection tool and copy and paste the graph or axes, a shaded area appears around the graph and axes, as shown in the image. In the environment settings, we have set the background to white as shown in the photo, but the shaded areas still appear using the above method. Is there any other way to make the shaded areas around the axes white?
Re: How to remove shading area around graph builder
I can see your .png. I know this has been an issue at somepoint with JMP, but I cannot replicate it with JMP 18.2.0. Do you have this enabled which was shown in the video?
These are my settings:
Transparent background for report PNG images enabled
Styles
Windows Specific
If I select graph builder, right click and select copy
It will come out as
to paint for example.
Which JMP version are you using? Where are you copy pasting your graph to ? Which section are you taking with Selection tool? This might also offer some help Saving Publication Quality Graphics with JMP?
Mr jthi.
Thank you for your answer and suggestion. I am using JMP® Student Edition 18.2.1. I copied and pasted the graph itself and the X and Y axis sections. I tried again, following your URL, but I couldn't. Could you see my previous report with PNG files? I will send it to you again. I would appreciate it if you could check it.
Styles
Windows Specific
It will come out as
Mr. jthi.
Thank you for your answer. I did not check " transparent background for report PNG reports".
I could do it. I appreciate you.
