fhc
fhc
How to remove automatic axis break
I'm a relatively new user to JMP and am struggling with something that I think should have a pretty simple solution. JMP automatically sets my axis to go from zero to the 200s, which is not what I want because I want to emphasize one of my groups being at zero, while the rest at in the 200s. I've explored x axis settings to no avail - what am I missing here? Thanks!
Re: How to remove automatic axis break
It seems like you have Nominal modeling type for Y-axis. Try changing it to Continuous (and Numeric if it isn't) and see if that helps / gives more options in axis settings.
fhc
fhc
There we go, easy! Thanks a bunch!
