JMPer08
How to refresh data in a new table within JSL script
Hello -
I am currently writing a script that will ultimately display a report for me. I can get all preceding tables/graphs to refresh accordingly when the data source's data is updated, but I'm not sure why the final table in the script doesn't update (labeled /* FINAL REPORT */). Am I missing a line so I can pull in data from the data source? Thank you in advance!
CumulativeData = Open(
	"/Users/NAME/Desktop/JMP/Customer1_Data_05232018.xlsx",
	Worksheets( "Cumulative_Data_Customer1" ),
	Use for all sheets( 1 ),
	Concatenate Worksheets( 0 ),
	Worksheet Settings(
		1,
		Has Column Headers( 1 ),
		Headers Start on Row( 1 ),
		Data Starts on Row( 2 ),
		Data Starts on Column( 1 ),ho
		Data Ends on Row( 0 ),
		Data Ends on Column( 0 ),
		Replicated Spanned Rows( 1 ),
		Suppress Hidden Rows( 1 ),
		Suppress Hidden Columns( 1 ),
		Suppress Empty Columns( 1 ),
		Treat as Hierarchy( 0 ),
		Multiple Series Stack( 0 ),
		Import Cell Colors( 0 ),
		Limit Column Detect( 0 ),
FitLineGraph = CumulativeData << Bivariate(
	Y( :Cumulative ),
	X( :Day of year ),
	Fit Where(
		:Customer == "Customer1",
		Fit Line( {Line Color( {212, 73, 88} )} )
CombinedTable = platform = Data Table( "Cumulative_Data_Customer1" ) <<
Bivariate(
	Y( :Cumulative ),
	X( :Day of year ),
	Fit Where(
Wait( 0 );
Report( platform )[Outline Box( "Bivariate Fit of Cumulative By Day of year" )][
Outline Box( "Linear Fit Customer==\!"Customer1\!"" )][
Outline Box( "Parameter Estimates" )][Table Box( 1 )] << Make Combined Data Table;
Report( platform ) << Close Window;
/* FINAL REPORT */
CampaignFulfillment = New Table( "Campaign Fulfillment",
	Add Rows( 1 ),
	New Script(
		"Source",
		Data Table( CombinedTable ) << Split(
			Split By( :Term ),
			Split( :Estimate ),
			Sort by Column Property
	New Script(
		"Make Combined Data Table",
		Bivariate(
			Y( :Cumulative ),
			X( :Data per day ),
			Fit Where(
		Wait( 0 );
		)][Outline Box( "Linear Fit Customer==\!"Customer1\!"" )][
	New Column( "Customer", Character, "Nominal", Set Values( {"Customer1"} ) ),
	New Column( "Data Guarantee",
		Numeric,
		"Continuous",
		Format( "Fixed Dec", 12, 0 ),
		Set Values( [3600] )
	New Column( "Program Length Target",
		Numeric,
		"Continuous",
		Set Values( [365] )
	New Column( "Data per day",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [9.90692146417355] )
	New Column( "X",
		Character,
		"Nominal",
		Hide,
		Exclude,
		Set Values( {"Day of year"} )
	New Column( "Y",
		Character,
		"Nominal",
		Hide,
		Exclude,
		Set Values( {"Cumulative"} )
	New Column( "~Bias", Character, "Nominal", Hide, Exclude, Set Values( {""} ) ),
	New Column( "Std Error",
		Numeric,
		"Continuous",
		Hide,
		Exclude,
		Set Values( [0.0596952471880355] )
	New Column( "t Ratio",
		Numeric,
		"Continuous",
		Format( "Fixed Dec", 12, 2 ),
		Hide,
		Exclude,
		Set Values( [165.958295355868] )
	New Column( "Prob>|t|",
		Numeric,
		"Continuous",
		Format( "PValue", 12 ),
		Hide,
		Exclude,
		Set Values( [4.75743232959739e-156] )
	New Column( "Intercept",
		Numeric,
		"Continuous",
		Hide,
		Exclude,
		Set Values( [-96.5323780670815] )
	New Column( "Estimated # at Target Date",
		Numeric,
		"Continuous",
		Formula( :Data per day * :Program Length Target )
	New Column( "Delta to Target",
		Numeric,
		"Continuous",
		Formula( :Estimated # at Target Date - :Data Guarantee )
	New Column( "Percent Deviation",
		Numeric,
		"Continuous",
		Formula( (:Delta to Target / :Data Guarantee) * 100 ),
		Set Property(
			"Color Gradient",
			{{"Variance Evaluation", 16387, {{252, 0, 7}, {235, 255, 10}, {33, 224,
			9}, {255, 248, 16}, {12, 108, 255}}, {0.00797872340425532,
			0.247340425531915, 0.502659574468085, 0.726063829787234, 1}},
			Range( {-10, 10, 0} )}
		Color Cell by Value,
		Set Selected
gzmorgan0
Re: How to refresh data in a new table within JSL script
You have an error in your script.  I believe you want this definition of CombinedTable.
    CombinedTable=Report(platform).... <<Make Combined Data Table;
Since the data table you are creating has this portion of JSL as a table script, it will need to be fixed as well.
Also, you have defined only one row in data table CampaignFulfilment, with fixed values. I see no JSL code to add data or make that table dynamic.
Please describe what you expect the script to do.
Bivariate(
	Y( :Cumulative ),
	X( :Day of year ),
	Fit Where(
Wait( 0 );
CombinedTable =Report( platform )[Outline Box( "Bivariate Fit of Cumulative By Day of year" )][
JMPer08
I'm not sure how to make my table dynamic and would like to make that happen. My goal is to have the CampaignFulfillment table, the split table, to auto refresh when the data source updates. The "Data by day" number in CampaginFulfillment is pulled from CombinedTable and that number is created when a fit line is added to the graph I created.
I have attached images of what everything looks like.
