GN19
How to receive numerical input from user, save as a variable and use variable in control chart builder as the set control limits
Hello, I am looking for a way to collect 6 numerical entries from a user at the beginning of a script. These 6 numbers need to be saved as variable which I am hoping to reference later as Levey Jennings control chart limits.
using the code below works with numbers but would like to change to reference the variables which have been set instead.
<Set Control Limits( {LCL( a ), UCL( b ), Avg( c )} )>
Re: How to receive numerical input from user, save as a variable and use variable in control chart builder as the set control limits
This question has been asked an answered multiple times withing the Community Discussion.  I suggest that you search the previous discussions.
I also strongly suggest that you read the Scripting Guide.  It contains documentation on the JMP Application Builder and window building that will be used in the development of your request.
Here is a simple script to get you started
nw = New Window( "input",
	modal,
	Lineup Box( N Col( 2 ),
		Text Box( "input 1 " ),
		ne1 = Number Edit Box( . ),
		Text Box( "input 2 " ),
		ne2 = Number Edit Box( . ),
		Text Box( "input 3 " ),
		ne3 = Number Edit Box( . ),
		Text Box( "input 4 " ),
		ne4 = Number Edit Box( . ),
		Text Box( "input 5 " ),
		ne5 = Number Edit Box( . ),
		Text Box( "input 6 " ),
		ne6 = Number Edit Box( . )
	bb = Button Box( "OK",
		val1 = ne1 << get;
		val2 = ne2 << get;
		val3 = ne3 << get;
		val4 = ne4 << get;
		val5 = ne5 << get;
		val6 = ne6 << get;
Show( val1, val2, val3, val4, val5, val6 );
To dig a little deeper, see Modal Dialogs  which uses an alternate way to retrieve the values.
