miguello
How to read table into list?
Let's say I have a table "dt" where column names are meaningless.
And I have a table "dt_source" with two columns - one column meaningless name and the other has corresponding meaningful name.
I'm trying to write a script that would rename columns from meaningless to meaningful.
Columns might be different, so I'm going to create a master table "dt_source" with corresponding values.
Now I have a script ready that takes meaningless and leaningful names from a list withing the script and renames colums for each pair if such meaningless name exists.
I want to be able to take those corresponding pairs not from typed in list:
name_in={"col1", "col2"};
name_out={"Age", "Height")
but from a table.
How do I read dt_name_source into two lists: name_in and name_out?
So far I have this:
Try(dt_source = Data Table("NameChanging.jmp"), Throw("Trying to open data table"));
If( Not( Is Scriptable( dt_source ) ),
dt_source = Open( "NameChanging.jmp" ), dt_source = Data Table("NameChanging.jmp");
Current Data Table(dt_source);
name_in=List();
name_out=List();
col_name_in=Column("name_in");
col_name_out=Column("name_out");
i=0;
For Each Row(name_in[i]=col_name_in[]; name_out[i]=col_name_out[]; i++);
But then it doesn't like it:
Subscript problem{1} in access or evaluation of 'Assign' , name_in =  /*###*/col_name_in[] /*###*/
If I try just a variable
For Each Row(name_in=col_name_in[]; name_out=col_name_out[]);
Then it's OK, but it's just one variable taking different values as the cycle goes.
And I need a list.
Can somebody give an idea how to handle this?
Re: How to read table into list?
I believe the following script will get the values into the lists you need:
If( Try( dt_source << get name, "" ) != "NameChanging",
name_in = dt_source:name_in << get values;
name_out = dt_source:name_out << get values;
miguello
Jim,
Thanks a lot for the reply. It works just fine.
However, I found that my renaming code does not work if there are no columns with one of the names from name_in (and there will often be columns in table that do not have ALL names from NameChanging.jmp table).
So far I have this:
for(i=1, i<=N Items(name_out), i++,
show(i); Try(col=Column(name_in)<<Set Name(name_out), Throw("NO COLUMN FOUND");
show(col)); show(i)
But cycle breaks after fifrst iteration when it does not finds the first name from name_in in the table.
miguello
Jim,
This seems to work fine for now. Let me know if this is a correct way of doing things:
show(i); If( !Is Missing( Is Scriptable( Try( Column( name_in ) ) ) ), col=Column(name_in)<<Set Name(name_out);
show(col); show(i))
I would probably do things a little differently:
Names Default to Here( 1 );
// Pointer to the data table to be changed
dt = data table("The name of the table to be changed");
    If(try(column(dt, name_in) << get name, "") != "", column( dt, name_in) << Set Name(name_out));
