FabioSaragoni
How to prompt user to name SQL query output data table and add date and time to filename?
Dear all,
I am asking for your expert advice on the following topic, since I am really new to JMP scripting.
I made a SQL query (invisible) through the Query builder but I need help to:
- prompt the user to insert data table file name (pop-up window);
- add date and time (ddmonyyyy:h:m:s) to the output data table
What I managed to script is here below:
dt=New SQL Query(
	Version( 130 ),
	Connection(
		"ODBC:DSN=DB001.00.G_FE_JMP15;DBQ=Y:\OFFICIAL_DATABASES\QA_Admin\Stability\DB001.00.G.StabilityStudies_FE_StudiesCompiler_JMP15.accdb;DriverId=25;FIL=MS Access;MaxBufferSize=2048;PageTimeout=5;UID=admin;"
	QueryName( "Query_DB001.00.G.StabilityStudies_FE_StudiesCompiler_10Jun2021" ),
	Select(
Column( "StudyID", "t1" ),
		Column( "TimePointID", "t1" ),
		Column( "StabilityClimaticConditions", "t1" ),
		Column( "TestMonth", "t1" ),
		Column( "ProgramComments", "t1" ),
		Column( "Test1", "t1" ),
		Column( "Test1Specification", "t1" ),
		Column( "Test1Units", "t1" ),
		Column( "Test 01", "t1" ),
		Column( "intTest1", "t1" ),
		Column( "Test2", "t1" ),
		Column( "Test2Specification", "t1" ),
		Column( "Test2Units", "t1" ),
		Column( "Test 02", "t1" ),
		Column( "intTest2", "t1" ),
		Column( "Test3", "t1" ),
		Column( "Test3Specification", "t1" ),
		Column( "Test3Units", "t1" ),
		Column( "Test 03", "t1" ),
		Column( "intTest3", "t1" ),
		Column( "Test4", "t1" ),
		Column( "Test4Specification", "t1" ),
		Column( "Test4Units", "t1" ),
		Column( "Test 04", "t1" ),
		Column( "intTest4", "t1" ),
		Column( "Test5", "t1" ),
		Column( "Test5Specification", "t1" ),
		Column( "Test5Units", "t1" ),
		Column( "Test 05", "t1" ),
		Column( "intTest5", "t1" ),
From( Table( "qry_ResultsUnion01_35", Alias( "t1" ) ) ),
	Where(
		EQ(
			_AllRows_,
			UI(
				Comparison(
					Base(
						"Continuous",
						Prompt(
							"StudyID:",
							Character,
							PromptName( "t1.StudyID_1" )
		) & In List(
			_AllRows_,
			UI(
				SelectListFilter(
					ListBox,
					Base(
						"Categorical",
						Prompt(
							"StabilityClimaticConditions:",
							Character,
							PromptName( "t1.StabilityClimaticConditions_1" )
	) << Run Background(invisible);
nw = New Window( "Name data table",
	<<Modal,
	<<Return Result,
	Text Box( "Insert data table file name" ),
	tableName = Text Edit Box( " ", <<set width( 400 ) )
If( nw["button"] == 1 & nw["tableName"] != "",
	dt << set name( nw["tableName"] ),
	dt << save as("tableName"||Format Date( Today(), "ddmonyyyy:h:m:s" )||".jmp");
Many thanks,
F
Re: How to prompt user to name SQL query output data table and add date and time to filename?
Most likely execution of your script finishes before the New Query(.
Try running the query in foreground instead of background OR use modal before query to get values from user and use postquery script to change the name after query finishes.
ih
Super User (Alumni) ih
Try changing your last if statement to this, it both fixes your tableName reference and removes the slashes and colons that were probably causing your issue:
//ask where to save the file (could skip this or define it in code)
fldr = pick directory( "Select where to save the file", "$Temp" );
//Save the file
	dt << set name( nw["tableName"] );
	dt << save as( fldr || nw["tableName"] || Format Date( Today(), "yyyymmdd" ) || "-" || Char( Hour( Today() ) ) || Char( Minute( Today() ) ) || Char( Second( Today() ) ) || ".jmp");
//Open directory where file was saved (not needed)
Open(fldr);
FabioSaragoni
Thanks for your reply!
I still have an issue at this level:
The error message I get is here below
Could you please help me solve it?
Thanks again,
F
FabioSaragoni
Executing the query in foreground solved the issue!
Thank you so much,
Fabio
