zetaVagabond1
How to prevent a data table window from appearing when creating it via script in JMP?
Hi everyone,
I have a JMP script that merges multiple tables into a single output table (see code snippet below).
Even though I’m trying to keep it hidden using:
Data Table("Combined_Output_Table") << Invisible(1);
the data table window still pops up briefly when it’s created (especially when using Concatenate or Join).
Is there a reliable way to keep the table from opening at all while the script runs?
I’ve tried:
  • Adding Invisible after creation
  • Using Show Window(0) or Hide Window()
  • Assigning it to a variable and setting invisible immediately
None seem to fully prevent the window from opening momentarily.
Sample Code-
//### Create combined output table
calcVersion = "Combined_Output_Table"; // Name of the final output table
nTables = N Items( tableNameList );
// Combine multiple batch tables into one
If(
	nTables == 1,
	Data Table( OpenTableNames[1] ) << Set Name( calcVersion ),
	FirstTable = Remove From( tableNameList );
	FirstTable << Concatenate(
		tableNameList,
		Output Table Name( calcVersion )
	// Close intermediate tables
	For( i = 1, i <= nTables, i++,
		Close( Data Table( OpenTableNames[i] ), NoSave )
//### Attempt to hide the window
Data Table( calcVersion ) << Invisible( 1 );
Level XIII
Re: How to prevent a data table window from appearing when creating it via script in JMP?
@zetaVagabond1 wrote:
I’ve tried:
add invisible during creation : )
open(filename, invisible)
even better: use private - this will speed up the data curation process.
Many Platforms allow you to add these settings.
Data Table( "Big Class Families" ) << Subset( All rows, Selected columns only( 0 ) , invisible);
myDT << Concatenate(tableNameList, Invisible);
It hurts that other platforms don't provide the setting - like Multi File Import!!
Private tables with Multiple File Import function
please vote to get this issue fixed:
Private option for Import Multiple Files
Level XIII
I’ve tried:
Level XIII
Instead of
If(
	nTables == 1,
		tableNameList,
you could write
myDT= new table(calcversion,invisible);
myDT << Concatenate(tableNameList, append to first table);
for each({dt},tableNameList, close(dt, noSave))
zetaVagabond1
Thanks for your detailed responses,I am not a seasoned JSL scripter and I have been trying to adapt to a legacy script. I find scripting in JSL very confusing  and daunting xD. I am more pythonic.
I figured my way around without much context but phew!!
