Hönig52
How to permanently tag specific data points in graphs over different data tables
Hi all,
I have a question regarding the tagging of specific data points in graph (GraphBuilder script). I would like to find an easier way, and maybe you can help. In the following, I describe how I usually do that.
I usually import Excel data tables to JMP when new data is added (cumulative).
With the new generated JMP table, I first copy the GraphBuilder scripts from the previous JMP data table and paste them in the new one.
In the JMP table, I need to tag specific data points and label them with the text stated in e.g. “column A“ for the specific row. I usually would do it like that:
JMP-data table:
  • First, I sort according to the names stated in “column A”,
  • Then, I tag all needed columns for the data points which need to be tagged in the graph
Script (graph):
  • I pin the tag to the specific tagged data point and rename it with the text stated in the specific row in “column A”
  • Of course, this I need to do this for every row (data point) I am interested to tag in the graph.
My questions:
  • Can this workflow somehow be done easier? E.g. over the column properties (in “column A”), e.g. automatic labelling / tagging of the data points in the graph script?
  • When I import the new excel data in a new JMP table, can the already tagged data points from the previous data table be imported? If yes how?
My JMP version: JMP 17.0.0
Re: How to permanently tag specific data points in graphs over different data tables
Have you tried how far you could get with Workflow builder Workflow Builder (jmp.com) for the automatization?
Hönig52
Hi Jarmo,
Thanks for your suggestion. I have seen this possibility but did not use it yet. I'll try out.
