bjbreitling
Im trying to write a script (so i can use it for JMP live) to dynamically apply spec limits queryed from another table.
My code to do this is below. Im not getting errors but its not working. I check the columns and they don't have the spec limits. The log is showing the following:
spec_limits = {LSL(lsl), USL(usl), Show Limits(1)};
:Column_Name << Get Data Type() = "Character";
:LSL << Get Data Type() = "Numeric";
"Column:";
column_name = "MST";
"LSL:";
lsl = 9;
"USL:";
usl = 12.5;
"Column:";
column_name = "FIBER";
"LSL:";
lsl = 7;
"USL:";
usl = 9;
"Column:";
column_name = "SULFUR";
"LSL:";
lsl = 1;
"USL:";
usl = 1.5;
"Column:";
column_name = "FAT";
"LSL:";
lsl = 3;
"USL:";
usl = 5;
"Column:";
column_name = "PROTEIN";
"LSL:";
lsl = 24;
"USL:";
usl = 27;
Here is the JSL Script:
<JSL>
myDT = Open Database(
    "APP=JMP;DATABASE=BBAnalytics;DRIVER={SQL Server};Description=BB Analytics Data Warehouse;Trusted_Connection=Yes;UID=%_UID_%;WSID=SFX-JPCZ724;SERVER=SFX-DWA01;DBCNAME=SFX-DWA01;",
    "SELECT * FROM [dbo].[myDT]",
    "myDT"
specLimitsTable = Open Database(
    "SELECT * FROM [dbo].[specDTTest]",
    "specDTTest"
// Iterate over the rows of the spec limits table
For Each Row(specLimitsTable,
    // Get values from the current row
    column_name = Column(specLimitsTable, "Column_Name")[Row()];
    lsl = Column(specLimitsTable, "LSL")[Row()];
    usl = Column(specLimitsTable, "USL")[Row()];
    // Set spec limits for the corresponding column in the main data table
    col_ref = Column(myDT, column_name);
    col_ref << Set Property(
        "Spec Limits",
	spec_limits = Column(myDT, column_name) << Get Property("Spec Limits");
	Show(spec_limits);
	show(column_name << Get Data Type());
	show(lsl << Get Data Type());
    // Show the applied spec limits for each column
    Show(
        "Column:", column_name,
        "LSL:", lsl,
        "USL:", usl
Re: Im trying to write a script (so i can use it for JMP live) to dynamically apply spec limits queryed from another table.
You are attempting to have JMP evaluate the contents of a JMP List.  Since a JMP List can contain just about anything, lists are not evaluated.  However, a wrapper can be placed around the code to evaluate the contents, and then be submitted to JMP for processing.  Try changing your Spec Limits code to
Eval(
	Eval Expr(
			"Spec Limits",
			{LSL( Expr( lsl ) ), USL( Expr( usl ) ),
			Show Limits( 1 )}
Eval(
	Eval Expr(
			"Spec Limits",
			Show Limits( 1 )}
bjbreitling
Thanks! This did the trick!
