Yogishan
Design space profiler
Is the design space profiler available only in JMP Pro? If not,is there any other way to get Design space profiler in JMP16?
Re: Design space profiler
I think Design Space Profiler was new feature in JMP17 https://www.jmp.com/support/help/en/17.2/index.shtml#page/jmp/design-space-profiler.shtml#ww490585. so maybe you can update to JMP17 (Similar post with some comments from JMP staffCannot use Design space profiler function in JMP 16.2  )
