lala
Level IX
How to pass parameters to the specified JSL in the graph fetch?
Examples in the index of software
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
gb = dt << Graph Builder( Show Control Panel( 0 ), Variables( X( :age ), Y( :weight ) ), Elements( Bar( X, Y, Legend( 7 ) ) ));
frame = (gb << report)[FrameBox( 1 )];
frame << Set Graphlet( Picture(  loader = Include( "$BUILTIN_SCRIPTS/hllib.jsl" );  hlp = loader:lazyLoad( "hllPresets" );  hlp:launchPie(); ), Title( "Pie Preset" ), Reapply( 1 ));
How does it pass parameters to hllib.jsl?
Which variable name is it in hllib.jsl?
11 REPLIES 11
Re: How to pass parameters to the specified JSL in the graph fetch?
What are you trying to pass?
lala
Level IX
You run the above JSL,
The cursor hovers over the graph, gets the "age" parameter, and gets the pie chart via hllib.jsl.
No pie chart appears without hllib.jsl.
So I think it's passing the age parameter.
I want to know how this example works.
Age is found from x-axis so it will be shown in the hoverlabel
	Show Control Panel(0),
	Variables(X(:age), Y(:weight)),
	Elements(Bar(X, Y, Legend(7))),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Graphlet(
				Picture(
					Graph Builder(
						Size(502, 435),
						Variables(X(:name), Y(:weight)),
						Elements(Pie(X, Y, Legend(10)))
lala
Level IX
Thank jthi!
That's probably not the answer I was looking for.
I found this example because I wanted to keep it  the form of
Because I also need to use Include("D:\test.jsl") in my own example application;The form of.
So I need to know how hllib.jsl gets parameter passing in the above example.
Thank you very much!
I have commented few times to you already, read the documentation regarding hover labels from JMP Help and especially
Work with the Hover Label Execution Context (jmp.com)
One way of seeing all the variables (to my knowledge) which you can access in hover labels local context, is to use Namespace("local") << get contents()
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Graphlet(
				Picture(
					Show(Namespace("local") << Get Contents());
					Graph Builder(
						Size(502, 435),
Namespace("local") << Get Contents() =
	{"_filters", {:age}},
	{"_mode", "Picture"},
	{"_where", ":age == 17"},
	{"_age", 17},
	{"_name", "KIRK, LAWRENCE, LINDA"},
	{"_groupings", {:age}},
	{"_firstRow", 38},
	{"_Mean(weight)", 140.666666666667},
	{"_underlyingRows", 3},
	{"_measurements", {:weight}},
	{"_displaySegName", "BarSeg"},
	{"_dataTable", Data Table("Big Class")},
	{"_summaryStatistic", "Mean"},
	{"_drillDepth", 1},
	{"_xaxis", 0},
	{"_yaxis", 0},
	{"_customData", [=> ]},
	{"_localDataFilter", "Local Data Filter(Close Outline(1), Add Filter(columns(:age), Where(:age == 17)))"},
	{"_whereExpr", :age == 17}
lala
Level IX
Yes, thank you for your patient help.
My understanding of scripts is limited.Never understood.
I am so that I can understand,
But it doesn't seem to work.
	Size( 528, 450 ),
	Variables( X( :sex ), Y( :height ) ),
	Elements( Bar( X, Y, Legend( 3 ) ) ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Textlet(
				Setup(
					local:encodedWhere = XML Encode( local:_where );
					/* Show() provides additional information about the
					HLEC variables in the log */
					Show( Namespace( "local" ) << Get Contents() );
				Markup(
<b>Groupings</b>: {local:_groupings}
<b>Measurements</b>: {local:_measurements}
<b>Summary statistic</b>: {local:_summaryStatistic}
<b>Filter columns</b>: {local:_filters}
<b>Where clause</b>: {local:encodedWhere}
<b>Graph type</b>: {local:_displaySegName}
<b>Data table</b> {local:_dataTable}
<b>Drill depth</b>: {local:_drillDepth}
<b>First Row</b>: {local:_firstRow}
<b>Underlying Rows</b>: {local:_underlyingRows}
a = {local:encodedWhere};
b = {local:encodedWhere}[1];
They are in local scope, so they don't exist outside hover label -> use them inside the hover label call.
lala
Level IX
yes
I try
Set Clipboard( {local:encodedWhere} );
in JSL 18 row
	Size( 528, 450 ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Textlet(
				Setup(
				Markup(
But it only get
I don't test anything in JMP18 as it isn't ready product so no idea if it behaves in different way (and if it does I will only comment that to JMP developers). JMP lists aren't evaluated, you will have to evaluated it or not use the list (there should be no need for adding the list in your case).
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Set Graphlet(
				Picture(
					Set Clipboard(Char(local:_where));
					//Set Clipboard(local:encodedWhere);
					Graph Builder(
						Size(502, 435),
