I am on JMP 18.1.2 and am attempting to create a matrix of check boxes. The final step which I cannot figure out, is how to dynamically create the H List Box based on number of rows.
This is my current code:
test = {"a","b","c","d","e"};
testFin = {};
rows = 2;
remain = Modulo(N Items(test), rows);
loops = 2 + (remain > 0);
//create a list that groups the original list in groups of 2 (rows)
for(i=1, i<= loops, i++,
test2 = {};
if(i != loops,
for(j = 1, j<= rows, j++,
test2[j] = test[1];
test = remove(test,1);
for(j = 1, j<= remain, j++,
test2[j] = test[1];
testFin[i] = test2;
//testFin = {{"a", "b"}, {"c", "d"}, {"e"}}
cb = {};
cancel_check = 0;
ttp = "";
for(i = 1, i<= N Items(testFin), i++,
if(i != N Items(testFin),
ttp ||= "cb["||Char(i)||"] = Check Box(testFin["||Char(i)||"]), \!n"
ttp ||= "cb["||Char(i)||"] = Check Box(testFin["||Char(i)||"]);"
/*ttp = "cb[1] = Check Box(testFin[1]),
cb[2] = Check Box(testFin[2]),
cb[3] = Check Box(testFin[3]);"*/
testw = new window("raaa", <<Modal,
H List Box(
parse(ttp);
H List Box(
Button Box("OK",
//testing
cbtemp = cb[1] << Get Selected();
Button Box("Cancel", cancel_check = 1);
if(cancel_check == 1,
Stop()
The error I get when trying to run it is:
Unexpected ",". Perhaps there is a missing ";" or ",".
Line 1 Column 30: cb[1] = Check Box(testFin[1])►,
The remaining text that was ignored was
,cb[2]=Check Box(testFin[2]),cb[3]=Check Box(testFin[3]);
The desired output (if I just replaced the parse with what ttp is and ran it) is attached and also below.
Thank you!
_________________
