jonasN
How to open Shape files fron Q-gis in JMP?
how to open shp.file from external source?
I have a shape file and other files imported originally from Q-gis.
I really want open this files in JMP for make or see the map and its atributes like poligons. But I cant open and convert.
Someone know about the steps for open shp.file from external source on JMP?
how do I translate these files into a format that JMP understands?
Thanks!
mlo1
Re: How to open Shape files fron Q-gis in JMP?
Usually it works as described in the documentation and you get
reasonable results if the map shape is given in decimal degree. Check your numbers for the unit of the maps you import.
file:///C:/Program%20Files%20(x86)/SAS/JMPSW/14/Help/index.html#page/jmp%2FEG_Maps_8.html
mlo1
Sorry for the local link. its part of the "Essential Graphing" documentation - Chapter "Create Maps"
The link that is provided appears to only be valid for individuals running JMP 14 in a 32 bit environment.
ian_jmp
Level X
You can look here in the (JMP 16) online help.
