shilpa
How to multiply user input by a constant number?
All,
I'm trying to multiply user input number by a constant. I need to use the final number (hoursBack) as a part of a web address.
local(
{Name= "ABCD", daysBack = "7", formError = 1, rv},
			While( formError > 0,
				formError = 0;
				rv = Dialog(
					Title( "Select Extract criteria" ),
					VList(
						HList( "Name:", Name= EditText( Name) ),
						HList( "Days Back", daysBack = EditText( daysBack ) ),
						HList( Button( "OK" ), Button( "Cancel" ) )
				If( rv["button"] < 0,
					Throw( "Bye!" )
				Name= rv["Name"];
				If( Name== "",
					formError
				daysBack = rv["daysBack"];
				If( daysBack == "",
					formError
				If( formError > 0,
					Dialog( "Missing required form input values" )
			Write( "Name=" || Name);
			hoursBack = daysBack*24;			//Getting an error here
			Status Msg( "Extracting data for " || Name);
			dt = queryData( "Newtable", hoursBack, Name); //Query data function is defined in a different part of the code
Getting the below error -
Cannot convert argument to a number [or matrix] in access or evaluation of 'Multiply' , daysBack * /*###*/24 /*###*/
shilpa
Re: How to multiply user input by a constant number?
I realized that it was because I was concatenating daysBack in the link. And I cannot concatenate numbers. I used temporary variables to convert daysback to number first and the resultant multiplied by 24, back to character. This resolved the issue. Thanks!!
num(daysback)*24
will get you past the problem where daysback holds a string.
The issue is that you are inputting your daysBack from an EditText() field, which returns a character string, not a numeric value.  Therefore it needs to be converted.  See my code below
local(
				formError = 0;
				rv = Dialog(
					VList(
					Throw( "Bye!" )
				Name= rv["Name"];
				If( Name== "",
					formError
				daysBack = num(rv["daysBack"]);show(daysback);
				If( daysBack == "",
					formError
				If( formError > 0,
			show("xx",hoursback)	;		//Getting an error here
			Status Msg( "Extracting data for " || char(Name));
shilpa
@txnelson Thank you. I tried what you suggested but am getting an error. I have attached the snapshot of the error
shilpa
The errors in your attached png file are referring to issues with variables called p1 & p2.  Those variables do not appear in the JSL that was previously examined, so I am only guessing as to the issue.  It is my assumption that p1 and p2 are numeric variables, or at least JMP thinks they are.  Numeric values cannot be directly used in a concatenation.  My suggestion is that you enclose each of the references of p1 and p2 in a Char() function. (i.e.  char(p1) )
