Liranlev
How to multiply rows with the same properties
I am trying to multiply certain rows based on their other properties. For example, I want to multiply the chance of having the same first and last name.
How can I do this in code?
Thank you.
Re: How to multiply rows with the same properties
You want to have something like this?
This is one fairly easy option
dt = New Table("Untitled",
	Add Rows(5),
	Compress File When Saved(1),
	New Column("A", Character, "Nominal", Set Values({"E", "E", "E", "E", "E"})),
	New Column("B", Character, "Nominal", Set Values({"L", "C", "L", "L", "C"})),
	New Column("C",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([5, 7, 10, 50, 7])
aa = Associative Array();
For Each Row(dt,
	name = :A || :B;
	If(!Contains(aa, name),
		aa[name] = 1;
	Multiply To(aa[name], :C);
newcol = dt << New Column("R", Numeric, Continuous, Formula(
	aa[:A || :B];
dt << run formulas;
newcol << delete formula;
My reading of @Liranlev is different from Jarmo's.  I read the request as to be able to take the values of chance in rows 1 & 3 and multiply them together and place them in row 7, and take the value of row 7 and place them in row 8.  This seems to be treating a JMP table as one might do this in Excel, but that aside, the script below will create the table.
	Add Rows(5),
	New Column("C",
		Numeric,
		"Continuous",
		Format("Best", 12),
For Each Row(dt,
	name = :A || :B;
		aa[name] = 1;
	aa[:A || :B];
dt << run formulas;
