matt_p
How to multiply multiple columns by a constant?
I am working with a data table near ~250 columns. For about half of the columns, I need to multiply the column by 1000 (for mA).
I would like to do this without having to create a new column every time (reassigning the column).
Throwing this code into my script, I  have
DataTable("Temp")<< (:Col_To_Multiply *= 1000);
This equation is not changing my column at all, and its also not throwing any errors.
This is only for one column, and keep in mind I need to do this for ~125 columns.
Any ideas on the equation or how to do this dynamically would be great.
Thanks in advance!
-Matt
ms
Super User (Alumni) ms
Re: How to multiply multiple columns by a constant?
Here is one way to do it (the script applies the factor 1000 to all columns. It is rather straighforward to adapt the for-loop to cover only columns of interest, i.e. loop over a list of those columns).
For( i = 1, i <= N Col( dt ), i++,
  Column( i ) << set values( (Column( i ) << get as matrix) * 1000 )
ms
matt_p
Thanks for the help, worked awesome!
This was the final code I ended up if anyone else has this question:
For( i = 1, i <= N Col(dt ), i++,
  a=Column(i) << get name;
  if ( contains(a, "Col_To_Multiply"),
  Column( i ) << set values( (Column( i ) << get as matrix) * 1000 ),
