debraj_guha
How to modify the heading of the bivariate analysis plot
I am trying to create a plot with the script below. When I create the plot using the Analysis tab in JMP, I get the plot as shown in the image named "Bivariate_Fit_Desired.PNG". While I put the same script in JSL, I get the plot as shown as in the image named "Bivariate_Fit_toFix.PNG". The area where I have the issue is circled in the images and the script is below. Thanks in advance.
Best
Debraj
ns:dt <<Fit Group(
           Bivariate(
                            Y( :THICKNESS_AVG ),
                             X( :DATE_TIME ),
                  Fit Spline( 0.1, Standardized, {Line Color( {213, 72, 87} )} ),
                  Where( :RIE Recipe == 150 ),
                                 Dispatch(
                         "2",
                                         ScaleBox,
                         {Max( 0.575 ), Add Ref Line( LCL_150_M, "Solid", "Black", "", 2 ),
                         Add Ref Line( CL_150_M, "Solid", "Black", "", 2 ),
                         Add Ref Line( UCL_150_M, "Solid", "Black", "", 2 )}
                                   Dispatch(
                           "Bivar Plot",
                                              FrameBox,
                            {Frame Size( 547, 401 ), Marker Size( 6 ),
                             Marker Drawing Mode( "Outlined" ),
                                               Row Legend(
                                                            :Data_Collection_Bin,
                                     Color( 1 ),
                                     Color Theme( "JMP Default" ),
                                     Marker( 0 ),
                                     Marker Theme( "" ),
                                     Continuous Scale( 0 ),
                                     Reverse Scale( 0 ),
                                     Excluded Rows( 0 )
KarenC
Re: How to modify the heading of the bivariate analysis plot
change your "Where(:column = 150)" to "By( :REI Recipe)"....
Run your analysis again by hand and compare the "save script" to the "save by group" script.
KarenC
debraj_guha
Thanks.....that did it.
