How to merge multiple graphs to one?
Greetings from Japan,
I'm Ryo and want to create merged graph like below image in JMP.
I've just tried several settings but seems difficult for me...
Does anyone can help me how to reach this?
Thank you and kind regards,
Re: How to merge multiple graphs to one?
Would be helpful to know how your data looks as that can be done multiple ways with JMP. Below are couple:
Split/wide data, drop then to Y-axis:
Stacked/long data, with overlay:
Byron_JMP
Try this
Use Tables > Stack.  Stack up your columns with the data you want to overlay
By default JMP will make two columns, Label is the column names and Data is, well, the data.
Then you can plot your X vs your Data, and put your Label into the Overlay role in the Graph Builder.
