lala
Level IX
How to make the content of the paste board into a table?
The pasted board contains previous content, blank content, and tabs at the beginning of each line, and forms a table
1 2023-09-09 00:00 A C 2 2023-09-09 00:00 B D
8 REPLIES 8
lala
Level IX
回复: How to make the content of the paste board into a table?
  • There may be Spaces
to
You might get quite far just by using Get Clipboard using open with blob
str = Get Clipboard();
Open(Char to Blob(str), "text");
then perform cleanup in JMP table
lala
Level IX
  • Can I make a table with multiple columns directly through regular substitution?
You can paste to a script window, clean up, and import. (You don't have to replace the tabs with commas and might not want to if the data contains commas.)
(view in My Videos)
lala
Level IX
Can this be done with JSL?I am still using JMP14 and cannot record.
t1=Regex(txt,"\!n\!n","\!n",globalreplace);
Thank Craige!
Sure, either save it to a file with a .CSV extension, or convert to a blob and open from the blob (and tell open it is a "text" file.)
Note the regex pattern uses \n for a newline and the regex replacement uses JMP's \!n.
change multiple consecutive newlines to a single newlinechange multiple consecutive newlines to a single newline
lala
Level IX
  • Cannot be implemented using copied data
on line 3, try changing txt to t1
The original text is likely to have CRLF pairs, but line 2's effect is lost by line 3 overwrite.
 you can also use the Hex(t1) function to see LF==x0A and CR==x0D
