vishwasanj
How to lock the scales in graph builder?
I couldn't find it in any of the documentation.
I am using a treemap and using a continuous number 1 to 8 on Group X and 1 to 8 on group y.
During filtering the data, Is there a way to lock the scales so that I could see all the missing data also.
Right now, it just shows the required data and treemap is scaled big or small depending on the number of count. Also, does anyone know how to display count in treemap graph builder?
Thank you
pmroz
Re: How to lock the scales in graph builder?
Click the red triangle next to "Graph Builder" and select Lock Scales.
vishwasanj
It doesn't work if you have the axes in Group X or Group Y instead of X and Y. Do you see the same thing?
vishwasanj
Here is an example
pmroz
I'll have to defer to the GB experts on this one.
vishwasanj
Anyone who can help me with this?
Thank you so much !
vince_faller
If the purpose is to include the missing data, why not just check "Include missing categories" under the hot button?
Vince Faller - Predictum
