Hanyuri
How to label multiple columns to every points in Graph builder
Hi buddies,
I have created a chart with multiples lines (multiples columns) in graph builder. When I labled values for columns (:sbl_rate; :Test module rate; :fab/sort rate; :assembly rate), instead of each point would be labled corresponding to its value, it showed all row values to each point. Please give me advices.
ih
Super User (Alumni) ih
Re: How to label multiple columns to every points in Graph builder
There might be a way to do this with row labels, but one option (albeit laborious) is to add transparent bars with labels.  This can be done graphically by:
  • Start with your chart
  • Remove all row labels
  • For each value displayed (SBL_rate & 3 more)
    • In top chart, right click, add a bar
    • On bottom left expand 'Variables' and only select one y variable
    • Change bar style to single
    • Set label to value
    • In legend settings change bar transparency to zero
  • Change legend settings to only show the lines and bars on the bottom
Names default to here( 1 );
dt1 = Open( "$Sample_data/Big Class.jmp", Invisible );
dt1Tab = dt1 << Tabulate(
	Set Format( N( 9, "Best" ) ),
	Add Table(
		Column Table( Analysis Columns( :height, :weight ) ),
		Column Table( Grouping Columns( :sex ) ),
		Row Table( Grouping Columns( :age ) )
dt2 = dt1Tab << Make Into Data Table;
dt1Tab << Close Window();
dt1 << Close Window();
dt2 << Graph Builder(
	Size( 929, 449 ),
	Show Control Panel( 0 ),
	Variables(
		X( :age ),
		Y( :Name( "Sum(height)" ) ),
		Y( :Name( "Sum(weight)" ), Position( 1 ) ),
		Y( :M ),
		Y( :F, Position( 2 ) )
	Elements(
		Position( 1, 1 ),
		Line( X, Y( 1 ), Y( 2 ), Legend( 13 ) ),
		Points( X, Y( 1 ), Y( 2 ), Legend( 16 ), Jitter( 0 ) ),
		Bar(
			X,
			Y( 2 ),
			Legend( 19 ),
			Bar Style( "Single" ),
			Label( "Label by Value" )
		Bar(
			X,
			Y( 1 ),
			Legend( 20 ),
	Elements( Position( 1, 2 ), Bar( X, Y( 1 ), Y( 2 ), Legend( 24 ) ) ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				13,
				Properties( 1, {Line Color( 51 ), Fill Color( 0 )} )
			), Legend Model(
				16,
				Base( 0, 0, 0 ),
				Base( 1, 0, 0 ),
				Properties( 1, {Line Color( 19 ), Fill Color( 0 )} )
			), Legend Model(
				19,
				Properties( 0, {Fill Color( 2 ), Transparency( 0 )} )
			), Legend Model(
				20,
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Grid Line Order( 4 ), Reference Line Order( 8 )}
		Dispatch(
			"400",
			LegendBox,
			{Legend Position(
				{13, [0, 1], 16, [-1, -1], 19, [-1], 20, [-1], 24, [2, 3]}
			), Position( {0, 1, -1, -1, -1, -1, 2, 3} )}
ian_jmp
Level X
I think you want to label only by 'SBL_lot_qty'. But notice that (in the Columns panel of the data dable), you have a little 'label' icon after the name of four other variables. You can right click and select 'Label/Unlabel' to set things up the way you want.
ih
	Add Table(
	Size( 929, 449 ),
	Variables(
		X( :age ),
		Y( :M ),
	Elements(
		Position( 1, 1 ),
		Bar(
			X,
			Y( 2 ),
			Legend( 19 ),
		Bar(
			X,
			Y( 1 ),
			Legend( 20 ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				13,
			), Legend Model(
				16,
				Base( 0, 0, 0 ),
				Base( 1, 0, 0 ),
			), Legend Model(
				19,
			), Legend Model(
				20,
		Dispatch(
			"Graph Builder",
			FrameBox,
		Dispatch(
			"400",
			LegendBox,
			{Legend Position(
Hanyuri
Hi ih,
It works exactly what I want it to be. :D Greatly appreciate!!!!
