Leo_Huang
assign marker style(line style) by "string" or specific "value" in column
Is it possible to assign the marker style by group name??Taking this script for example,I want to  let column "mean" line-style always be  dashed and column "Range" line-style be solid in the all page(page by process step) of graph.Some of my page(process step) don't have the "Mean"data.If I script like this,the line style will not fixed at all my plot.
Graph Builder(
	Size( 562, 477 ),
	Variables( X( :date ), Y( :Mean ), Y( :Range, Position( 1 ) ) ),
	Elements(
		Line( X, Y( 1 ), Y( 2 ), Legend( 9 ) ),
		Points( X, Y( 1 ), Y( 2 ), Legend( 10 ) )
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				9,
				Properties( 0, {Line Style( "Dashed" )} ),
				Properties( 1, {Line Style( "Solid" )} )
		Dispatch( {}, "Graph Builder", FrameBox, {Marker Size( 3 )} )
I am trying to did like the following script. I assign the properties to a "string"(or a sepecific value in a column).But it doesn't works. Could anyone help?? Thanks!
Properties( "Mean", {Line Style( "Dashed" )} ),
Properties( "Range", {Line Style( "Dashed" )} ),
Re: assign marker style(line style) by "string" or specific "value" in column
Here is a sample that I believe matches what you want
dt = Open( "$SAMPLE_DATA\big class.jmp" );
// Set the X column to be continuous to match your sample
dt:age << modeling type( continuous );
// Set the markers
dt << color or mark by column( :sex, marker theme( solid ) );
// Create the chart
Graph Builder(
	Size( 534, 490 ),
	Show Control Panel( 0 ),
	Variables( X( :age ), Y( :height ), Y( :weight, Position( 1 ) ), Group X( :sex ) ),
	Elements(
		Points( X, Y( 1 ), Y( 2 ), Legend( 8 ) ),
		Line( X, Y( 1 ), Y( 2 ), Legend( 10 ) )
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model( 10, Properties( 0, {Line Style( "Dotted" )} ) )}
The best way to generate the script for things like this is to run the sample interactively, getting it the way you want it, and then to simply Save the Script from under the red triangle.
