pomemelom
How to joining two columns with JSL
Hi I am new to JSL, and I got stuck in a seemlily easy task.
Say I have two columns A and B, and have some missing values.
I'd like to create a new column to be the join of column A and B.
As shown in example below.
Re: How to joining two columns with JSL
Here is a couple of simple examples
dt << New Column( "New Column", character, formula( name || sex ) );
// or
dt << New Column( "Second New Column", character );
For( i = 1, i <= N Rows( dt ), i++,
	dt:Second New Column[i] = dt:name[i] || dt:sex[i]
)are
// or
)are
meperry
I am having the same issue, but the code provided here does not work.  I am dealing with continuous data, perhaps that is the problem? Or is it that my variable names are longer than SAS allows, so using them in JSL creates an error?
My data subset looks like such:
StdURM1BLFIStdURM1BLMI
-0.0316815.
.-0.33056098
 and I would like the third column to contain the data from the other two (or keep a missing data value as necessary), e.g.:
StdURM1BLFIStdURM1BLMIZscore
-0.0316815.-0.0316815
.-0.33056098-0.33056098
Thank you!
ian_jmp
Level X
So long as only one of the two columns has a non missing value, you could try 'Sum()'. Look at the formula in the table below:
New Table( "Both",
	Add Rows( 4 ),
	New Column( "a",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [., 1, ., 3] )
	New Column( "b",
		Numeric,
		"Continuous",
		Set Values( [., ., 2, 4] )
	New Column( "c",
		Numeric,
		"Continuous",
		Formula( Sum( :a, :b ) )
) e
meperry
The sum function works!  Thank you!
Level XII
It's amazing how easy such things are in JMP - even by hand (no problem if the patterns are irregular and the table has 5 mio entries).
Just watch this video by @brady_brady :
Columns Menu  (~ 2min)
Alternative approach:
use the Merge Columns add-in  by @john_madden
