KTo
KTo
How to join tables without creating a new table?
LS,
I want to add data from a table to a main table. This can be easily done by using the "join" option from the tables menu. However, this generates a new datatable while I want to add data to the main data table.
Now I have to close the original main table and than overwrite the original file with all potential risks.
Is thisd possible, and how (note that I know that JMP uses scripts, but I am not familiar with building my own scripts
thanks
Kees
Re: join tables without creating a new table
In the Join dialog box, there is a check box, that allows you to "Update main table with data from second table"
11 REPLIES 11
Phil_Brown
Instead of JOIN. Use the UPDATE option in the Tables Menu.
PDB
KTo
KTo
HY Phil,
Thanks for your reply. Unfortunately, and indeed unexpectedly because I also expected "update" to update the whole table, this command updates columns AND stores the update in a new table.
Thanks
Kees
miguello
Strange, in my case it still creates a new table.
If you use
Tables=>Update
it will not create a new table
jwiltsie
This creates a new data table per the JMP 18.1 documentation
Data in the original table are updated with data in columns that have the same names. The results are displayed in a new data table.
I think this didn't used to create a new data table. Was this changed recently?
I found a JMP Wishlist item for this: Tables join: option to update main tablePlease upvote the Wishlist item if you would like to see this implemented in JMP.
Tables=>Join
always creates a new data table.
Tables=>Update
does not create a new table
jwiltsie
Tables => Update does not work for my situation, since it cannot do an Inner or Right Outer Join.
Phil_Brown
You are looking at the documentation for JOIN DATA TABLES. There is an option when joining tables, to "Update main table with data from second table". This is different from the other function -- UPDATE DATA TABLEs
See the following link for the details: Update Data Tables
PDB
