TIP_USER
How many devices can open JMP simultaneously using one account?
Re: How many devices can open JMP simultaneously using one account?
To my knowledge this isn't public knowledge but the more accounts you use behind single sign-in (JMP18+), the more frequently you might have to verify your JMP. In my experience it is somewhere between 3-4 when you might start running into constant verifications.
