SengYew
How to interpret lambda values from Box Cox Y Transformation?
From the Figure 3.48 Box Cox Y Transformation from JMP webpage
The plot shows that the best values of λ are between 0.1 and 2.0. The value that JMP selects, using interpolation between the best two values in the 0.2-unit grid of λ values, is 1.124.
https://www.jmp.com/support/help/en/17.0/#page/jmp/box-cox-y-transformation.shtml
I would like to know how to interpret this lambda value : 1.124. After interpret, what should I do? will this data transform to normality?
MRB3855
Re: How to interpret lambda values from Box Cox Y Transformation?
Hi @SengYew : You may want to start here.
https://en.wikipedia.org/wiki/Power_transform
