UserID16644
Level V
How to interchange columns using JSL?
Hi all,
I have a CSV file that is being used in JMP. However, I need to interchange columns 1 & 2 with Columns 7 & 8. How to do it using JSL. It looks something like this:
Original File
123456789
Interchanged columns
783456129
Re: How to interchange columns using JSL?
Do you wish to reorder your columns or just move the data around inside the columns? This should help you with re-ordering of the columns BUT it won't work the same with all JMP versions due to how <<move selected columns did work in some version(s)
dt = New Table("Untitled 2",
	Add Rows(0),
	Compress File When Saved(1),
	New Column("1", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("2", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("3", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("4", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("5", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("6", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("7", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("8", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("9", Numeric, "Continuous", Format("Best", 12), Set Values([]))
wait(1); // demo purposes
collist = dt << Get Column Names("String");
col_order = {"7", "8", "3", "4", "5", "6", "1", "2", "9"};
dt << Move Selected Columns(col_order);
UserID16644
Level V
 This works well. But just one question, is it also possible to move only the data inside the columns and not its headers? How is it done using JSL?
You can either just change the Header names rather than moving the data, or you can actually move the data.  See example below
names default to here(1);
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "$SAMPLE_DATA/Big Class.jmp" );
// Move header is easier than moving all of the data
:weight << set name("new name");
:height << set name("weight");
// One way to move data
theHeights = :weight << get values;
theWeights = :new name << get values;
:new name << set name("height");
:weight << set values(theWeights);
:height << set values(theHeights);
