uday_guntupalli
Level VIII
How to index into a table box of check boxes
All,
      I have a m by n Table box of check boxes. I am wondering, how I can set some of them selected.
          LB_b = Lineup Box(N Col(1));
	  nR = 10;
	  nC = 10;
	  SCB1 = String Col Box( "", {} );
	  For( i = 1, i <= nR, i++,
			SCB1 << Add Element( Char( i ) )
	  TB1 = Table Box( SCB1 );
	  For( i = 1, i <= nC, i++,
			Insert Into( TB1, Check Box( Repeat( {" "}, nR ), <<Set Heading( Char( i ) ) ) )
	  LB_b << Append(TB1);
	  T = New Window("Test",TB1);
        When I look at the tree structure, I wonder why I am unable to access the elements. I tried  something like the following  with no luck. Also, the goal is not to be able to select a column of check boxes, but a single checkbox in the matrix.
TB1["CheckBoxBox(1)"] << select ;
Best
Uday
pmroz
Re: How to index into a table box of check boxes
This code will set the checkboxes from a saved matrix of 1s and 0s.
// Set some random values in this matrix
saved_cbmat =
[	1 0 0 1 0 0 0 0 0 0,
	0 0 0 0 0 0 0 0 0 0,
	0 1 0 0 0 0 0 0 0 0,
	0 1 0 0 0 0 1 0 0 0,
	0 1 0 1 0 0 1 0 1 0,
	0 0 0 0 0 0 0 0 0 1,
	0 0 0 0 0 0 0 0 1 1,
	0 0 0 0 0 0 0 0 1 0,
	0 0 0 0 0 0 0 0 0 0];
n = 10;		// # rows
m = 10;		// # cols
a = 1::n;
// Create a list of empty text fields as checkbox labels
cb_list = {};
for (i = 1, i <= n, i++,
	cb_list[i] = "";
cbmat = j(n, m, 0);
// Create the window
nw = new window("Test",
	tb = table box(
		ncb = number col box("", a),
	okb = button box("OK",
		for (i = 1, i <= m, i++,
			for (k = 1, k <= n, k++,
				cbmat[k, i] = cb[i] << get(k);
		show(cbmat);
		nw << close window;
// Create an array of checkbox columns
cb = {};
// Add the checkboxes
	cb[i] = checkbox(cb_list);
	cb[i] << set heading(char(i));
	tb << append(cb[i]);
// Preload the checkboxes from the saved matrix
		on_off = saved_cbmat[k, i];
		cb[i] << set(k, on_off);
You have 2 reference issues with
The first is that
is looking for an Outline Box with the title "CheckBoxBox()".  That is, you have placed "CheckBoxBox()" in quotes, and there for it is not looking for a CheckBoxBox() object, it is looking for an object with the title "CheckBoxBox(1)".
Secondly,
<< Select
is not a message that CheckBoxBox() has available to it.
TB1[CheckBoxBox(1)] <<  get selected ;
would be what you want, except for the fact that << get selected returns the string values for each of the check boxes selected, and since all of your string values for your check boxes are set to " ", that will be all you will be returned. So what you will need to do is to loop through each of the check boxes, and find the values. Here is a simple example
For( c = 1, c <= 10, c++,
	For( r = 1, r <= 10, r++,
		If( T[CheckBoxBox( c )] << get( r ) == 1,
			Show( c, r )
pmroz
Here's a way to do what you need:
n = 10;		// # rows
m = 10;		// # cols
a = 1::n;
cb_list = {};
	cb_list[i] = "";
cbmat = j(n, m, 0);
	tb = table box(
		show(cbmat);
		nw << close window;
cb = {};
cbmat =
[	1 0 0 0 0 0 0 0 0 0,
	1 0 1 0 0 0 0 0 0 0,
	0 0 1 0 0 0 0 0 0 0,
	0 0 1 0 1 0 0 0 0 0,
	0 0 0 0 1 0 1 0 0 0,
	0 0 0 0 0 0 1 0 0 0,
uday_guntupalli
Level VIII
@pmroz  and @txnelson ,
        Thank you for your responses. However, if I may, I think the primary part of my question that is, how do I set them to selected(My bad - I should have asked checked) doesn't seem to have been addressed. Could either of you guide me as to how I can check any of the checkboxes ?
         I think @pmroz  's response provides a way to index to the checkbox, but I think it references them by column, not so much by each individual check box. I will try and illustrate in a little more detail what I seek:
         The snippet I posted gives me a matrix of selectable checkboxes like so:
         Now, should a user make his selection, I am able to unload the selection using the following:
NW = New Window("Test",
					VLB0 = V List Box(Align(center),
									  LB_b
VLB0 << Append(
				H List Box(
								BB_TargetMatrix = Button Box( "OK",
																ResMat = {};
																// loop through each row
																		ResMat[i] = {};
																		// loop through each column getting values
																		For( r = 1, r <= nC, r++,
																				ResMat[i][r] = TB1[CheckBoxBox( r )] << get( i )
																ResMat = Matrix( ResMat );
															)// end of button box
							 )// end of H List Box
           However, I would like to know how I can the table box with some of the checkboxes pre-checked. I have a matrix the same size as the table box, which I would like to use to set the checkboxes checked.
Best
Uday
pmroz
saved_cbmat =
n = 10;		// # rows
m = 10;		// # cols
a = 1::n;
cb_list = {};
	cb_list[i] = "";
cbmat = j(n, m, 0);
	tb = table box(
		show(cbmat);
		nw << close window;
cb = {};
