UersK
How to implement JS algorithm with JSL?
There is a website data request to download the need for dynamic verification, web page JS has a specific algorithm.
function getRnd() {
    return parseInt(Math.random() * 10000) + "=" + parseInt(Math.random() * 10000)
//Returns a random number
function getRuntime() {
    var c = new Date();
    var b = "";
    var f = c.getFullYear();
    var h = c.getMonth() + 1;
    var g = c.getDate();
    var a = c.getHours();
    var d = c.getMinutes();
    var e = c.getSeconds();
    b = f + "-" + h + "-" + g + " " + a + ":" + d + ":" + e;
    return
//Returns a timestamp
Its request parameter is
[{"ReqId":"1000","Market":"0","Sort":"zj08","CodeList":"","Desc":"1","Page":"1","PageSize":"100","Xgtj":"","Want":"hq00,hq01,zj00,zj01,zj02,zj03,zj04,zj05,zj06,zj07,zj08,zj09,zj10,zj11,zj12,zj13,zjn00,zjn01,zjn02","EXPTOKEN":"35de5f29c393b370e92a99c19ea2bb8f9a5d81e0296dedf6d952531a0982450e","modname":"mod_zjlx"}]
9 REPLIES 9
UersK
Re: How to implement JS algorithm with JSL?
The token is dynamic, and the 32 bits in the figure are the real-time timestamp when the data is requested, which is calculated according to the above algorithm
How to use JSL to achieve this algorithm, the final use of JSL can achieve the website data download.
Thanks Experts!
UersK
b3313cca81a3f56de75d0e252dc3d17d	{~62~33~33~31~33~63~63~61~38~31~61~33~66~35~36~64~65~37~35~64~30~65~32~35~32~64~63~33~64~31~37~64};
b3313cca81a3f56dca5503f02eb3b23f	{~62~33~33~31~33~63~63~61~38~31~61~33~66~35~36~64~63~61~35~35~30~33~66~30~32~65~62~33~62~32~33~66};
54b0ea31266538a5ed4b311f78e45577	{~35~34~62~30~65~61~33~31~32~36~36~35~33~38~61~35~65~64~34~62~33~31~31~66~37~38~65~34~35~35~37~37};
54b0ea31266538a5dc3eb30831ba9a8e	{~35~34~62~30~65~61~33~31~32~36~36~35~33~38~61~35~64~63~33~65~62~33~30~38~33~31~62~61~39~61~38~65};
6f6513e99b16e00bd952531a0982450e	{~36~66~36~35~31~33~65~39~39~62~31~36~65~30~30~62~64~39~35~32~35~33~31~61~30~39~38~32~34~35~30~65};
230e438970e32162d952531a0982450e	{~32~33~30~65~34~33~38~39~37~30~65~33~32~31~36~32~64~39~35~32~35~33~31~61~30~39~38~32~34~35~30~65};
3a37657866190524d952531a0982450e	{~33~61~33~37~36~35~37~38~36~36~31~39~30~35~32~34~64~39~35~32~35~33~31~61~30~39~38~32~34~35~30~65};
762baf39305e1ed6d952531a0982450e	{~37~36~32~62~61~66~33~39~33~30~35~65~31~65~64~36~64~39~35~32~35~33~31~61~30~39~38~32~34~35~30~65};
16f080f9e5d542afd952531a0982450e	{~31~36~66~30~38~30~66~39~65~35~64~35~34~32~61~66~64~39~35~32~35~33~31~61~30~39~38~32~34~35~30~65};
478a2b0371d01b8cd952531a0982450e	{~34~37~38~61~32~62~30~33~37~31~64~30~31~62~38~63~64~39~35~32~35~33~31~61~30~39~38~32~34~35~30~65};
I collected the timestamp and its binary text for several different time request parameters.
I just don't know how to use JSL to do this algorithm.Ask a JMP expert for help.Thanks!
UersK
  • I'm trying to analyze it this way
UersK
  • Is there a function for JMP?
Thanks Experts!
You should provide more background information if you expect any help here. So you have an algorithm coded in JavaScript? Have you learned JSL yet? What is the nature of the problem you have encountered so far?
UersK
Thanks Experts!
Yes, this is an HTTP download problem with JSL, and this algorithm only involves timestamp verification of request parameters.
I JSL manual, can do normal HTTP using JSL download data.
JSL does offer wide range of different functions related to datetimes
and then maybe you can use character functions to build rest of your string
and HTTP Request functions to build your query
UersK
Thank jthi!
Still in the HTTP request time check problem, this parameter must be submitted at the time according to the above JS algorithm to successfully download the data.
My complete download of the JSL code is pictured.
UersK
fiddler
Different time demands, to change only timestamp this part
Thanks Experts!
