SimonFuchs
How to have one JMP datafile with several tables
Hi JMPxpert,
I created several DoE sheets for a bigger screen and now I have 4 different JMP table datafiles. How can I upload them into one datafile and work with them (model them) still separately? I dont want to have four different JMP be opened on my desktop. In Excel tables I also have several tables accessible with the several spreadsheets.
Thanks for the help here!
Have a nice advent time
3 ACCEPTED SOLUTIONS
SDF1
Re: How to have one JMP datafile with several tables
Hi @SimonFuchs ,
  Try looking into JMP Projects. They can manage and store several data tables in one file.
Good luck!,
DS
Jeff_Perkinson
You can do this with JMP Projects.
Learn more:
-Jeff
If using Projects is not your 'cup of tea,' you could also concatenate all the tables into one, while adding a new column to indicate which table the data originally came from. In JMP, Tables...Concatenate, and be sure to select the "Create source column" option.
For analysis, you can use the Data Filter to only analyze the data you want.
SDF1
Hi @SimonFuchs ,
Good luck!,
DS
Jeff_Perkinson
Learn more:
-Jeff
