elcid5441
How to get the color from a cell in an HTML table?
I have an HTML table at work with different colored cells.  For example, a green cell means equipment is running, red means that it is not qualified.  I can open the HTML table into JMP, but I have no idea how to also import the cell color.
Re: How to get the color from a cell in an HTML table?
I think you might have to parse the colors from html code and then recolor in JMP. Or re-color them in JMP based on some conditions if possible
