Ted1
How to get the Compare Slopes option to appear in the Fit Least Squares report?
I have 3 columns of data, a nominal LABEL identifies which of 3 populations the row is from, a continuous DURATION is the independent variable, and a continuous EFFECT is the dependent variable.  Using Analyze>Fit Y by X from the menu I can get 3 regression lines with ANOVA for each, but I want an ANCOVA comparing the slopes of the 3 lines. According to JMP help: "In the Fit Least Squares report, the Compare Slopes option appears when there is one nominal term, one continuous term, and their interaction effect for the fixed effects. This option produces a report that enables you to compare the slopes in an analysis of covariance (ANCOVA) model."  but I can't find this option...
Re: How to get the Compare Slopes option to appear in the Fit Least Squares report?
Fit Y by X launches the Bivariate Fit platfomr. You want to start with Fit Model. Select Duration and Label, then click the macro button to get the ANCOVA terms. Effect goes in the Y role.
Ted1
