miguello
How to get rid of unnecessary "Variability Gauge" OutlineBox in Variability Chart?
All,
Need help with Display Boxes today.
I'm forming a report that I will later save in PPTX for the customer.
Since I want to group several plots on one slide I form an OutlineBox with the text that I want to be the header on the slide and then place a picture of the plots I need into that Outline Box. In parallel, I also display that in a separate window.
Here's the example script:
vc = Variability Chart(
	Y( :height, weight ),
	X( :sex ),
	Connect Cell Means( 1 ),
	Std Dev Chart( 0 ),
	Points Jittered( 1 )
lb = Lineup Box( N Col( 2 ) );
	For Each( {rvc, index}, vc << Report,
		lb << Append( rvc  );
vc << Close Window;
nw = New Window( "Variability Report", Show Menu( 0 ), Show Toolbars( 0 ), lb );
rw = New Window( "To Save PPTX", Show Menu( 0 ), Show Toolbars( 0 ), Outline Box("Heading for PPTX", lb << Get Picture));
Here nw is the window that I see, and rw is the window with pictures that will get exported to PPTX.
Now, when I do variability plots, I have them wrapped in this outline box that just says "Variability Gauge". You see that both windows have it. How do I get rid of it?
I tried to extract the inner Outline Box like this:
lb2 = Lineup Box( N Col( 2 ) );
		subrvc = rvc << XPath("/OutlineBox/OutlineBox");
		lb2 << Append( subrvc  );
rw2 = New Window( "To Save PPTX", Show Menu( 0 ), Show Toolbars( 0 ), Outline Box("Heading for PPTX", lb2 << Get Picture));
but I cannot append subrvc (the inner outline box) to my LineUp Box:
Not a display in access or evaluation of 'Append' , Append( subrvc ) /*###*/
Any way to get rid of that outline box? Maybe wrap my plot in something that IS a display, but is essentially invisible? I tried Broder Box but it did not work.
Thanks,
M
miguello
Re: How to get rid of unnecessary "Variability Gauge" OutlineBox in Variability Chart?
Hmmm... As usual, as soon as I post the question, I find the answer. Or at least looks like this should work:
subrvc in the script above is actually not a DisplayBox[OutlineBox], it's an array of them with only one element.
So all I need to do is change script like this:
		lb2 << Append( subrvc[1]/*THIS HERE!*/  );
miguello
