ricardor
How to get partitioned sum of squares in ANOVA results of fit model
Not just CTSS, SSmodel and SSE, I mean SS for individual predictors. How do I get it from fit model results?
Thank you.
Re: How to get partitioned sum of squares in ANOVA results of fit model
You will need to open up the Effect Tests outline item. If you do not see that outline item, then look under the Model red popup > Regression Reports > Effect Tests
Dan Obermiller
