How to get new column to populate cycles in large data set for multiple cycles on the same sample?
I have some very large data sets (>1million rows) of numerous samples that have been tested in a cyclical fashion. The same sample has gone through 100's of cycles and I'm hoping to find a way to quickly add the cycles to my data table.
The test starts at zero displacement and then runs to a peak force (varies depending on which cycle it is) and then returns back to a zero/near-zero value. I'd like a way to add in the cycle without having to manually scroll through millions of rows of data adding cycles.
Re: How to get new column to populate cycles in large data set for multiple cycles on the same sample?
I added this formula to the Cycles column.  It increments the Cycle number each time it detects a change from decreasing values, to increasing values.
As Constant( x = 1 );
If( :Sample != Lag( :Sample ),
	x = 1
If( Lag( :Compression ) > :Compression & Lag( :Compression, -1 ) > :Compression,
	x = x + 1
x;
Below is a graph where I have created a local data filter, which is set to only display cycles 3,4 and 5 from sample 3.  I believe this is what you are looking for
In your data it seems like you could just use Sample to determine the cycle?
Each sample has numerous cycles of compression/decompression in them (100's) and I'm hoping to find a way to break down each Sample # into each cycle within that sample.
	x = 1
	x = x + 1
x;
Thank you so much Jim!
