How to get content of text edit box into "variable"?
PS_Ato
I'am looking for an alternative to manual change of variable ("Inspection Lot") within the script itself.
former sript:
Open Database(
"DBQ=X:...
WHERE User1 LIKE '%Inspection Lot%'", "HSS"
I tried this - s.below, but it does not work. The script is running, but the "variable" was not used. Probably something is wrong with the format. Looking for advice.
Thank you.
new script version:
win = New Window( "Edit Box - Enter the Inspection Lot",
<<Modal,
<<Return Result,
Text Box( "HSS Test: Enter the Inspection Lot" ),
texteditbox = TextEdit Box( "Inspection Lot" ),
Text Box( "Pressing OK - display of HSS graphs will be done automatically." ),
Button Box( "OK" ),
Button Box( "Cancel" )
Open Database(
"DBQ=X:...
WHERE User1 LIKE '%{"texteditbox"}%'", "HSS"
pmroz
Re: How to get content of text edit box into "variable"?
A few suggestions for posting in this forum:
  • Indent your code (right-click > Reformat script)
  • Paste the code into the forum using the <JSL> button.  That will retain syntax colors
On to your problem.  My code checks to see if a value was entered into the text box.  If there is a value there it creates a SQL string using the variable sql, and then calls Open Database.  Your code calls open database with the IF command inside it.  That won't work.
Try this code:
	If( tbox_value != "",
		sql = Eval Insert(
			"SELECT TRBallShearHSBTTSF.Sample, Test, ....
FROM TRBallShearHSBTTSF INNER JOIN SSBallShearHSBTTSF
ON TRBallShearHSBTTSF.Sample = SSBallShearHSBTTSF.Sample
WHERE User1 LIKE '%^tbox_value^%'");
		dsn_string = "DBQ=X:\- ...HS.mdb;DefaultDir=X:\- ...;Driver={Driver do Microsoft Access (*.mdb)};DriverId=..;FIL=MS Access;FILEDSN=X:\...dsn;MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;";
		Open Database(dsn_string, sql, "HSS-Dage 4000");
pmroz
You are calling the variable for your texteditbox "texteditbox", which is allowed but not good programming practice.  Here's how to use the value entered in the textedit box:
tbox_value = "";
	<<Modal,
	<<Return Result,
	tbox = Text Edit Box( "Inspection Lot" ),
	hlistbox(
		Button Box( "OK",
			tbox_value = tbox << get text()),
if (tbox_value != "",
	sql = evalinsert(
"SELECT foo, bar
   FROM utopia
WHERE User1 LIKE '%{^tbox_value^}%'");
	show(sql);
	Open Database("DBQ=X:...", sql, "HSS");
If I enter ABC the log shows this:
sql = "SELECT foo, bar
   FROM utopia
WHERE User1 LIKE '%{ABC}%'";
PS_Ato
thank you very much for your fast reply. Unfortunately I don't know much about programming and I'am still struggling - see below:
Sorry - I did not understand, where to put the "IF-Command".
Open Database(
	"DBQ=X:\- ...HS.mdb;DefaultDir=X:\- ...;Driver={Driver do Microsoft Access (*.mdb)};DriverId=..;FIL=MS Access;FILEDSN=X:\...dsn;MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;",
		sql = Eval Insert(
WHERE User1 LIKE '%^tbox_value^%'",
			"HSS-Dage 4000"
pmroz
Try this code:
		sql = Eval Insert(
PS_Ato
Many, many thanks - my first dialog box works - I'am so happy!!! :-) :-)
