UserID16644
How to get column sum according to same column values?
Hi all
How to calculate the Total Qty if they have the same code? I am currently using Col Sum(:Qty) but it is getting the sum of all column values. I just want the sum of values with the same code & date
DateCodeQtyTotal Qty
10-23-230049
10-23-230059
10-23-230166
10-24-230333
10-24-230444
10-25-230568
10-25-230528
Re: How to get column sum according to same column values?
You can add the Code column as a grouping variable to achieve this - The required formula is:
Col Sum (Qty , Code)
I've put this in the attached table to illustrate.
Hope that helps,
Stuart
Here is the Scripting Index description of the Col Sum()
Note that the function allows for By Variables. Example 4 from the same Scripting Index entry, illustrates the use of the By variables with columns Age and Sex specified as By variables
dt << New Column( "Sum for Each Age and Sex Group",
	Formula( Col Sum( :height, :age, :sex ) )
With the results
