PhamBao
How to get characters between brackets within a string??
Hi everyone,
I have a string like below " [CDO600705010] [S 88ABCV A B IT] [C23204348IT] "
Do you know how to get characters between open and close bracket
For instance:
CDO600705010
S 88ABCV A B IT
C23204348IT
Sincerely
Re: How to get characters between brackets within a string??
s=" [CDO600705010] [S 88ABCV A B IT] [C23204348IT] ";
one = word(2,s,"[]");
show(one);
one = "CDO600705010";
show(one);
PhamBao
Amazing! Appreciate It works like miracle
Jeff_Perkinson
Word() is the function every JMP user should know.
If you learn only one Formula Editor function, Word() is the one
-Jeff
I would definitely go with Word() or Words() with this one, but there is a Character Pattern thingie in JMP. It is fairly difficult to learn and it might have a bit limited use when compared to more simple methods (I haven't bothered to learn it). Script modified from a script found from  Re: Extract text from string (post also has explanation of the matching)
// see https://community.jmp.com/t5/Discussions/Extract-text-from-string/td-p/450420
txt = " [CDO600705010] [S 88ABCV A B IT] [C23204348IT] ";
sp = Pat Span("abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890 ");
found_list = {};
Pat Match(
	txt,
	"[" + sp >> match + ("]") + Pat Test(
		Insert Into(found_list, match);
		0;
show(found_list);
// found_list = {"CDO600705010", "S 88ABCV A B IT", "C23204348IT"};
But matching between multiple brackets could be one place where I could see myself using Character Patterns.
See also Scripting Guide > Types of Data > Pattern Matching
I like @txnelson's approach. I often use it. The character functions are handy!
Here is another approach using Regex() instead. It is not a solution. It is an illustration of how you might parse each string. I show two search patterns, but other patterns are possible. I wonder which way is faster, as it might be a consideration with many strings.
Names Default to Here( 1 );
string = {  "[CDO600705010]", "[S 88ABCV A B IT]", "[C23204348IT]" };
n = N Items( string );
For( s = 1, s <= n, s++,
	Show(
		Regex( string[s], "([\w\d\s]+)", "\1" );
	Show(
		Regex( string[s], "[^\-[\]]+" );
