Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
I d like to create a formula column (sum or mean etc.) with sub groups. The sub groups should be selected by rows, for example all 5 following rows drom a data table or in general all N rows. Any ideas to solve this with row()?
As I understand it, Local() simply let variables to be defined and evaluated within the context of the column formula, eliminating risk of interference with global variables with the same name. Parameters are used in optimization problems, i.e. the nonlinear platform.
